Hello,
I have a 64gb Flash Voyager memory stick made by Corsair
had it a few weeks.
The problem is the stick keeps loosing files i saved to it
Using Win XP Pro with SP3.
Drive properties report 62.4Gb total space. In NTFS file system.
Used is 3.62Gb videos, documents, pictures etc but them on last night.
Today plug it into my computer all i can see is 1 file 32Kb in size
Its done this before but seemed to fix itself.
Any idea what could be wrong with it ??
Many Thanks
Ben
had it a few weeks.The problem is the stick keeps loosing files i saved to it
Many Thanks
Ben
