Could get something like this for the soundbar - https://www.amazon.co.uk/Beetronic-...ywords=soundbar+bracket&qid=1701689195&sr=8-4 - connects to the VESA mount of the TV.
It was the safest height I could fit to, the fireplace I've no idea how it was filled in but it sounded very hollow lower with possibly very thin plasterboard.
edit: I found a few articles that state a 55" would be 61" from floor to centre. I just measure mine and I'm not far off to be honest.
HOW HIGH SHOULD A 55-INCH TV BE MOUNTED?
A 55” TV should be around 61 inches from the floor to the center of the TV screen.
Personal taste, I suppose, but I think that is way too high. I have mine at 40". About eye height when you are sat down.
My 65" is 25" bottom to 58" top, I raised sofa with a 3.5" sofa riser.
I thought the same, mines definitely higher than this and works for usDoesn’t look high at all if that a standard height ceiling
Both my 65” ones are higher then that
