£650 gaming build help
8 Jan 2012
Hey there finally joined up to this site as i need help you see i have £650 to build a gaming pc but not build it myself just like use a website configurator, i have seen a build on a ebay shop where they claim the system can run battlefield 3 at ultra settings i will post a link to it and someone can let me know if it would be worth £650, but i am thinking maybe someone can give me a build or show me a pre built system sold on overclockers, im looking to run pc games from year 2007 and up for example oldies like command and conquar kanes wrath and call of duty 4 too crysis 2 and battlefield 3 i dont mind playing on high settings for battlefield 3 also im not looking for a 3d system and im not fussed about if it is wireless and has a good sound card in it just purely graphics ram and cpu performence also i notice on this build posted below is 16 gb or ram needed for better performence or does the 8gb do the trick, also im looking to buy a amd based computer as its a lot cheaper than intel.
http://www.ebay.co.uk/itm/AMD-X6-FX...t=UK_Computing_DesktopPCs&hash=item1c2101de6a
No that okay, maybe read the FAQ first:
http://forums.overclockers.co.uk/faq.php
Within that budget, do you need a screen, mouse,keyboard, OS (windows)? Or just the tower itself?
Windows 7 home os and no mouse, keyboard or screen but i am looking to have a hdmi port on the pc for a hd screen so just the tower with all the parts inside so i can just plug my keyboard and mouse and screen in and yeah i should have read the faq i think i was just a bit quick to post and not notice.
No worries will spec you something now. I'm guessing you'd rather have one built for you than build yourself?
Maybe this one with a 550Ti and Windows 7 options?
You don't have to, but its an option.
EDIT: oops forgot the link:
http://www.overclockers.co.uk/showproduct.php?prodid=FS-237-OK
Also if you can afford the 560Ti instead it is much better
That is definatley a option have you any others in mind would it not be much cheaper if i have the higher end amd cpu instead of intel as that would slash the price would it not? or does the amd cpu not have enough juice to run the 560ti?
BTW, you can probably get more for your money if you built it yourself. It is not massively difficult, if you have the time to research it and make sure you know what to do. Plus there are plenty of people on here to help you. I can find some guides etc... for you if you wish. It's another option for you anyway!
With that budget you could squeeze a 2500k in there, do you have anything you can throw in temporary until you get more money, like an old hard drive/burner/case?
Well i might sound really lazy but i know how to build one so does it save me a lot of money building myself as i thought if they are pre-built they are not sold on for much more, and thank you for your help so far i will definatly buy from this site this week so if you can then find me the parts so i can put them together that would be great its just i do not really have any tools to build one just problem is if i was to pick myself i might get incompatable parts which is what i afraid of making mistakes on.
Build it yourself, its fun having new things!
no sorry i do not but you see i am left with £725 after paying out bills etc but i dont know how much tax and national insurance will come off my pay so if it is not much i will have a higher budget.
Thank you so much for your help now from experience is the i3 cpu good enough to run battlefield 3 at high settings as i have seen videos on the 560ti 1gb running at ultra settings but i think they was running a i5 cpu with it.
Running at ultra settings is always difficult to say. It depends on so many things, there are so many settings you can change. For a start what resolution is your monitor?
The i3 is a great CPU IMO, and will be fine for gaming. You'd struggle to get an i5 in that budget without getting a crap GPU.
Save £83 somehow and you have a 2500k that can be overclocked and then you could get a cooler next time.
EDIT: £72 if you get OEM
