650d Watercooling Help
28 Feb 2006
Hey guys, im considering adding some watercooling into my machine to extend the life a bit before a full on upgrade.
I'm pretty clueless about watercooling in general but I assume its going to do better than what i've got now.
Stock Corsair 650D Case
2500k at 4.5ghz under a Gelid tranquilo
R290x Reference cooler, runs so unbelievably extremely hot.
Im looking at the corsair cpu cooler range and this corsair solution for the gpu
https://www.overclockers.co.uk/showproduct.php?prodid=HS-029-CS
Problem is I see H55, H60, H75, H80I, H80GT, H90, H100i, H100i GTX, H105, H110 and I havent got a clue whats suitable for my case, card and gpu.
Thanks for any advice.
I have a H100i fitted to my 650D Case & it's been faultless in the 12 months I've run it.
Temps on my 4770k @4.5ghz rarely exceed 60c.
That's awesome! It's always nice to hear positive feedback from you guys :)
Thanks you for taking the time to share your experience with both the H100i and 650D.. I appreciate it!
