6600gt problems :(
22 Dec 2005
hi,
im new to the forums and i was wondering if anyone could help me,
ive got an msi 6600gt 128mb PCIE
and when i load games like bf2 and earth 2160 they crash horribly during gameplay..
to even get to play for more than five minutes in earth 2160 i have to run everything on low settings and window box it
with battlefield 2 its like if lots of things are happening in one screen my gfx cant handle it and it just turns off,
maybe it could be because of overheating?
my 3dmark05 results are low like 19fps
im sure this card cant be that bad
afterall i paid £130 for it
thanks for any help it would be greatly apreciated
Muncan
Im not sure about the games, but check the temps if you think it is overheating (coolbits, rivatuner) and giving the fps for 3dmark05 isnt helpful, we need the score (should be about 3300 - 3800).
sorry to bump this but ..
what are peoples opinons on me buying a 3rd party vga cooler.. i think a couple of the zalman ones look good... the gfx itself runs at 47c when idl i think its partly becuase of my micro atx case (aspire xq pack) .. everythings cramped together
Thanks
im sorry i didnt quite get you, do you mean every single driver on my computer or jus the ones todo with nvidia etc
just got this error when playing cs:s:
It then closed cs and froze for a bit
Thanks
Thanks
I think it's a good idea. I have a 6600GT (Zenith or something arbitrary) and on the stock cooler, it ran at 55 idle up to about 80/85 load - I've now got an arctic silencer on it (bought from the good people of OcUK ;) ) and its now 45 idle, 55-60 load. Peace of mind for me, and I won't overclock it simply because its a dreadful overclocker. (even on water it wouldn't do that much more than stock, whereas my old XFX one went up to insane speeds for a 6600GT)
If it's drivers, download driver cleaner and clean up all the nVidia ones before you try to install them. Don't want to bodge it up even more!
Thanks for the replys i updated my drivers to forceware 83.10
but is it normal for these 3 files:
nview.dll
nvshell.dll
nvwdmcpl.dll
to not be found?
Could this be my problem
Thanks
hey guys..
Well i have basiclly sorted this out , whilst browsing some msi support forums
found a lot of other people with the same problem as me
the mobo and gfx card have some incompatibilty problems and i hould be able to RMA the board for an updated one :)
Thanks for all the help and input though
