Permabanned
- 11 Jan 2019
- bedlam
So i picked up a cheap 6600k on ebay.
the listing said it was ok but run hot, was cheap so i snapped it up.
As you can see at stock speeds on an aftermarket cooler it hits 100c with intel burn test, however i have noticed the Vcore will go upto 1.312v under load.
Do i de-lid or do i just under volt it, or could the massive Vcore be a fault on the CPU
i have seen the chips do 4.7 @ 1.35v
