Yes its an asus hero viii
So its better to have the asus because it can do all cores?
Mine is currently not overclocked - I don't feel like I am running anything that is taxing the cpu that much to do it yet....
I guess lowering it to 1.26V manually you will lose the advantages of the cpu underclocking when idle as it will constantly be using the same voltage at full speed or low speed?
one thing that annoys me though is that even doing everyday tasks the cpu boosts up / heats up instantly and the cpu fan spins up fast and then slows down straight away....
Im getting confused now
So I need to change Load Line Calibration to lower? (ill check what it is)
Checking manual - default is AUTO? I presume mine is (is there a way to check what value AUTO is setting it to?)
What does that do and how does that effect the high voltage?
Cheers
Is this it? Which ones do I use? Thanks
CPU Core/Cache Voltage [Default: Auto]
Options: Auto / Manual Mode/ Offset Mode/ Adaptive Mode
For Manual Mode:-
CPU Core Voltage Override Auto / 0.600 -> 1.700
For Offset Mode
Offset Mode Sign (+ / -) / Offset Mode Value Auto / 0.005 - 0.635
For Adaptive Mode
Additional Turbo Mode CPU Core Voltage (0.25 - 1.925)
Offset Voltage [Auto] 0.001 - 0.999
My friend owns the same mobo, that's why I asked you if you own an Asus mobo.
With his 6700K the mobo defaults Load-Line Calibration to level 8 or 7 making the CPU go as high as 1.456-1.472V during heavy load. We lowered it to level 1 and tested for stability (OCCT 4.4.1 Large/ Small Data Sets). And it was completely stable, while still maintaining 4.2 GHz across all cores.
