- 24 Aug 2015
tried that but still goes higher than what I set it, would lowering llc level fix this as from what I read the auto settings can cause the voltage to go higher than what you set it tooDidn't see the linkbut it looks like the motherboard is overvolting the CPU which is pretty standard for auto settings. I'd suggest setting a manual vcore of 1.2 would help a lot with the temperatures, maybe that had been done before and got wiped when it was reset resulting in a noticeable increase in temps.
