- 10 Aug 2011
The 6700K is more expensive than the 7700K. Why? It doesn't make sense to me.
My basket at Overclockers UK:
Which one are you going to buy?
that case won't take a tall card like the EVGA FTW mind you.
It would make absolute sense to go with the 7700k - I was only jesting when asking which one to go with![]()
no worries I have that case.That was something that I had in mind, but hadn't checked the numbers yet to be sure if it would fit. Thanks though.
Consider a smaller m.2 or ssd plus normal hdd £569.99 seems a massive ammount on an m.2 alone
also the m.2 is really overpriced. look around
