6800nu unlocking question
12 Oct 2005
Cheam
I have managed to unlock the vertex shaders on my gfx card. However, whenever I unlock the 4 extra pipelines I get loads of artifacts on 3d mark 05. Is there any way I can stop the artifacts and what causes the artifacts?
Thanks
Mike
Is your card overclocked ? If it is, then try running at stock with the extra lines enabled.
If not or if it's still the same, then the pipelines are damaged and causing these artifacts, nowt you can do I'm afraid.
