So bad. So asking for trouble.
Hi - why trouble ? I have used this as well for some time - interested to know if there is some issue with it.
cj
I played bf today at 1920x1200 ultra settings 4xAA vsync on and got 40 frames steadily, going up occasionally but not really any lower! With vsync off it didn't make any difference to frames.
That was with unlocked shaders an 950/1450 clocks
I think when people say they are playing ultra on bf3 they actually mean custom ultra without msaa. I can play at ultra no probs without msaa at around 60fps. The only thing missing is msaa. If i use msaa x2 i drop to around 45 fps. I have not even bothered to try 4xaa as i reckon mid 30s would be average with constant dips into the 20s. My resolution is 1920x1200 and i am talking sp. I reckon mp would be even worse.
Why?? As long as you read the instructions you cant go wrong. Good little program![]()
I'm hoping to upgrade CPU and RAM next year. I didn't realise that CPU would make such an impact on graphics![]()
You were 1 point off getting a 1337 score![]()
While thats partially true, I haven't used it since the XP days. Plus it caused major problems when Windows 7 Service Pack 1 was released. Regardless of doing it correctly.
http://forums.overclockers.co.uk/showpost.php?p=21286642&postcount=14
The results shouldn't really be compared together since you used two different versions of the same benchmark. Couldn't you benchmark you new setup with Heaven 2.5?
I run BF3 on Ultra at a steady 70fps easily. Ive got the 6950 Toxic.
a Single 6950 doing 70 fps constant?
