6970 Power consumption
26 Dec 2009
London
I have a 4890PCS+ overclocked. I want to change it for 6970. Is a 520W PSU enough to power it.
I've compared reviews and it seems (though not consistently) the 4890 consumes almost 100Watts more than the 6970.
So basically if someone can confirm the 6970 consumes less than an overclocked 4890, then I know the 520W should be enough.
Looking at your system specs in your sig it seems you have a pretty high end motherboard. Not only that, but a quite old motherboard that could quite probably suck down a fair bit of power. You also run an overclocked Q6600 which again is a very high NM chip. Add in your overclocks and personally I wouldn't risk it.
It also depends on the rails and how they are laid out/how many amps they deliver. If it's a single rail of 50 amps or above you might just get away with it.
Right I added your system specs into Outervision and applied your overclock.
I can hear your PSU squealing from here.
I wouldn't risk it, the psu can easily become too hot and unstable when it is using more wattage than it is rated that.
If you can get a 7950/70 they should run fine on that psu, not only that but they will be a much faster card aswell.
If your not looking for a new gpu then either upgrade your psu to 600w min or forget it tbh.
What the heck are you talking about the 6970 is a 250watt card the 7970 is a 300watt card.
I'd take those psu calculator figures with a pinch of salt as it said for my old gfx card (3870) my system was recommended a 794W supply. I ran it on a 400W supply for a few years before i upgraded to a TX650. (that old 400W supply is still going strong in another system) With the 6970 in place it says 946W. I'm fairly certain i could stick another 6970 in and still be fine with the 650W supply.
OK so those calculators are rubbish.
So am i right in believing that since my PSU can run an overclocked 4890 it will run a 6970?
Reference HD 6970 has a TDP of 250 W compared to a HD 4890 with 190 W.
The 300-400W quoted for a HD 4890 would be for the whole system.
You do need to find what your PSU is rated for the +12V as that accounts for pretty much all a modern PC's usage.
Not according to several reviews. The 4890 at peak with max gpu stress consumes over 300-400W (cant remember exactly but itwas that high). And 6970 consumes less than 300.
If the 4890 used that much my PC wouldn't turn on.
Yeah according to that im using 1000W but i get by fine on a 750w xfx black edition psu.
You must be filling it in wrong, or you've got about 20 Hard Drives plugged in.
At last, someone talking sense, those figures tie in with the 54w difference I got with the PSU calculator :D
Guru3D reviews.
Identical systems apart from the motherboard used.
HD 4890 System with GPU in FULL Stress = 370W
HD 6970 System with GPU in FULL Stress = 361W
Now that's a better indication of the relative power consumption ;)
If anyone wants to bother (because I cant be) my system pulls 520W from the wall peak with Crysis 2 and that's the most I've seen it pull with a real program.
Not including the monitor and speaker system obviously.
