6th gen small motherboard please?
16 Nov 2023
United Kingdom
Hey guys, this is a bit of an odd one, but I'm looking for a Micro ATX, or a mini ITX motherboard that would work with an i7 6700k + GTX 960 combo. They are from an old computer that I can't be bothered selling for parts, but they are sitting in a huge case. So I figured I'll pick up a small form MB and transplant it all into a tiny case to keep as a spare machine, or give to a family member if they can use it.
Ideally I'd like the case to be new(if that's even still a thing) and as cheap as possible, but I don't want some dodgy no name brand either. I found a case that will work for 15 quid, so that leaves more spare for the MB if needed.
All the naming for the older generations is really confusing to me so that's why I'm struggling to figure this one out. Hope you can help me.:)
Thank you, so will any of these work with this CPU?
Yep, they shouldn't need a bios update or anything like that.
Is there no Intel/AMD version sockets like with the most recent ones?
Are you referring to B360 (Intel) and B350 (AMD)? If so, then no, the chipsets I listed should only be available for Intel CPUs (socket 1151v1, to be exact).
Sorry, I mixed up the socket with the chipset. I get it now.:) Thank you for your help.
