7 Year Old 700w PSU
24 Nov 2008
Mighty Mighty Luton
Hey all
I have a 7 year old PSU currently in my 7 year old PC. Its a OCZ StealthXStream 700W.
There hasn't been an issue with it since installation in 2009. I am looking at getting new internals for my PC -
6600k
Z170 M/B
8Gb RAM
GTX1060 6Gb
M.2 for OS
SATA SSD for games
Looking at the power draw and the connections everything is there. Do I need a new PSU or is the one I have going to be sufficient saving me some money for a better GFX card?
I can't remember whether that unit was highly regarded at the time, but given the age of it I would replace it anyway. The last thing you want is for it to expire and take some of your new hardware with it.
You won't need a 700W unit to replace it - a quality 500W unit should be plenty.
Most respectable brand PSU's are designed to run for thousands of hours, so in reality your PSU is probably fine and will go on for years to come.
However with the cost of PSU's being so low these days compared to 7 years ago when you bought it I would probably just upgrade it on the side of caution. The above poster is correct too, things are a lot more efficient these days as well, a good 500W PSU would be adequate for your needs.
Thats what I was thinking, I can get one for under £70 which doesnt add too much to the cost.
Been offered £200 for my old PC anyway so some of the cost is absorbed!
If the PSU passes the OCCT PSU test and the computer is stable in all states then I see not much reason to change it out.
Unless I could see its capacitors bulging, then I would bin and replace.
The biggest problem this model (and quite a lot of their others) suffered from was high ripple. It's not exactly a bad unit but considering it's age and that you have splashed out on a load of new expensive components I would probably be replacing it now and keep it as a back up/testing psu. A new efficient 450-550w psu would be a very good match for your components.
Rather than start a New tread I was wondering the same, corsair HX620, it's never given me any issues and was a well regarded psu, planning on using it in an i5 new build, crazy or prudent?!?
