£700 spec need help
23 Oct 2012
Hello overclockers, wanted some guidance on a spec i put together to build myself a gaming PC.
YOUR BASKET
1 x MSI GeForce GTX 660 OC Twin Frozr 2048MB GDDR5 PCI-Express Graphics Card £179.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £167.99
1 x MSI Z77A-G43 Intel Z77 (Socket 1155) DDR3 Motherboard £79.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) £66.66
1 x OCZ ZS Series 550W '80 Plus Bronze' Power Supply £49.99
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £25.99
1 x Samsung SH-S222BB/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.99
Total : £632.59 (includes shipping : £12.50).
My max budget is £700 but i would like to bring that down to about £500 if i could, i wanted some money leftover to play around with for example i'm looking into getting one of those bigfoot network cards but not sure yet.
I think the i5 3700k is overkill for what i need, if you guys were gonna replace it with some i3 model which one is good for me? Also the graphics card is overkill can someone suggest one that will last me 2 years? thanks a lot. :)
@Idleman i want a gaming pc that will last at least 2 years, i play all kinds of games so hard to just give a quick list.
@Sparx oh that graphics card is really good at that price
so you guys think i might as well go with an i5?
@idleman i want a gaming pc that will last at least 2 years, i play all kinds of games so hard to just give a quick list.
@sparx oh that graphics card is really good at that price
Yes. :)
ok thanks for the help, the last spec idleman posted looks like what i was looking for. I noticed you added a cooler did i miss that from my first spec? or did you assume i was gonna overclock? I am new to building computers by the way should have said earlier sorry.
No the CPU comes with a stock heatsink and fan. If you plan to overclock at a later date, then grab the 3rd party cooler that Idleman added. :)
