£700 system, would these specs work?
9 Mar 2008
Hi guys,
im looking into putting myself together a new pc, mainly for gaming, editing movies, so I thought id put together some decent high end stuff. £700 is what im looking for, maybe slightly more at £750.
Im not too worried about OC, but I take it its there if need be.
Just wondering what you guys think of this spec, and would you change anything?
thanks
I would get the 64-bit edition of Vista, along with 4Gb of RAM and a SATA DVD-RW drive
The rest of the looks fine to me though.
Looks fine with the changes, if you want to get closer to budget again then you could change the graphics card from the OC2 model to one that isn't pre-clocked - most will reach the same sort of speeds anyway.
