R
I would have thought having the bottom fans as intake would be more efficient than exhaust. Doubt its the issue though, as that isn't exactly a tiny ITX case![Stick Out Tongue :p :p](/styles/default/xenforo/vbSmilies/Normal/tongue.gif)
What temp does it settle to when running a CPU bench?
It's the 50 degrees on startup that's bugging me. Computer was off all night, instantly reading 50 in BIOS?
My case is this
Fan setup:
* Radiator on top of case
* 2 140mm fans intake at front
* 2 140mm fans out at the bottom of the case
Might be worth noting that the water temp usually reads as 30 degrees.
I know its a small case so temps will be higher but I'm not sure they should be this high?
