750d airflow help?
2 Dec 2009
Hi Ocuk.
(Yay- this is my 100th post)
Recently I acquired a 750d and proceeded to fit my rig including a h100Gt to the top panel.
Unfortunately the pipework sits on the rear 140mm case fan.
has anyone come across this?.
I have temporarily turned the rear fan around as an intake - so as the pipework can rest on the rear fan guard instead of the blades.
But this leaves me with:
top 2x rad fans Exhausting (120mm each) push setup.
Rear 140mm fan in-taking (sp?)
Front 2x 140mm fans In-taking.
Lower PSU fan exhausting downward.
Would this not leave me with too much positive airflow inside the case?. its quite well ventilated though. loads of mesh and grilles everywhere.
regards
Callum
You could just remove the rear fan (or get a slim 15mm fan). Airflow front panel if you need more airflow. Personally, I'd rather have positive pressure as the excess of cooler air passes over everything and pass out the vents and give the exhaust fans more to pull on.
