775 cooler recommendation
4 Aug 2006
Can someone suggest a 775 socket cpu watercooler (to be bought second hand) similar to the Corsair / Antec ranges, which doesn't require the motherboard to be removed to install? If there is such a product.
If they can all be installed without removing the motherboard then please excuse my ignorance :) I just want to be able to slot it in.
You'd probably be fine with a low end air coooler for that situation, but if you want an AIO, then you'd be looking at removing your motherboard to install it.
