brakeinup said:
Hi (first post!)
I have just purchased a load of kit from OCUK including a XFX 7800GT Extreme which also has a fan running at 100%. Although the card performs fantastically it makes my system too noisy overall. The fan never changes its speed throughout the boot process.
Am I within my rights to RMA it back to OCUK as it is still within 7 days of delivery? Or is there a fix that has been found yet - maybe a BIOS update for the card?
Thanks
I think you need an RMA from XFX, though I am not sure. Try phoning OcUK first, but I'm basing this on the entries for XFX cards that appear on OcUK pages:
2 Years Manufacturer Warranty - Call XFX UK on 09068354400 for technical support and RMA services.
Good luck if you try that. They fobbed me off with the old "reinstall Windows" line. Which doesn't fix the problem for me, or several other people who tried it, but you might get lucky. Ditto for XFX support by email.
There is a known issue with the fans on the XFX 7800GT cards containing "UDE" in their model code (UDE3, UDE7 and UDER). I have seen only one report of the UDF7 model with this problem. This is a known issue affecting many people. It is not a couple of malcontents who don't know what they're doing talking crap. One of the many people talking about the issue on XFX's forums has access to a shop and has tried multiple combinations of PCs and different 7800GT cards. The cards with the problem have it in each PC, which have different hardware and different drivers.
It appears to be possible to get an RMA from XFX due to this issue in the USA. Two XFX employees have stated this on XFX's forums (Pan and RyanXFX). Support elsewhere seems to be behind the curve.
It also affects some cards from other manufacturers, notably BFG.
The issue appears to stem from coolers that don't follow the standard nvidia spec, plus some unknown factor(s), but it does seem to be a fault with the cards themselves, at least in some cases. One person has reported a fix, but it involves earthing yourself and then touching a specific transistor on the card while your PC is on. I don't fancy trying it myself, especially since you have to do it every boot. If you do fancy trying it, see the 1st post from Percster on page 3 of
this thread
Check out the threads that another poster has provided links for. There are hundreds of posts in a dozen or so threads, just on XFX's forums. There are many more elsewhere on the net.
