7800GTX replacement cooler.
29 Feb 2004
The fan on my old 7800GTX seems to have had better days, as the card at idle is quite warm (65-67C). It's not too dusty, so I think the fan is just giving up :( as it is very old.
Looking for a replacement for it, not sure what to get though. There are plenty of newer coolers that claim they fit it, but with such an old card there are no reviews/pictures with them fitting or if there was any issues. All the coolers that were reviewed for it are discontinued now (like the arctic silencer). I'm also not sure if it's a reference pcb or not, can't remember if manufacturers made their own back then or just stuck with reference. The card is a MSI NX7800GTX 256MB. I saw another card that looked just the same, but was Gigabyte, so I think it's reference, not sure though.
So any suggestions? or just going to have to grab one that claims it fits and hope for the best?
Thanks.
For the cost of an aftermarket cooler you may as well have a peak around the MM and pick up a 8800GTX/S or 9800GTX for the same price...
Hmm, didn't realise a replacement could be grabbed for that sort of price. Might go down that route then, no great rush as the card is not in my main machine, so plenty of time to look around :).
