Hi all
Was after a bit of advice and guidance.
Bit of a ramble coming up.......be warned.
T Mobile signal in my flat is proper pump (unable to make any calls when indoors) so after a letter of complaint, they sent me a SignalBox gratis.
All was good, yet i have recently noticed that this keeps failing. I believe that the failing is coincident with downloading TVOD via Wifi.
What I was thinking is that the download is using all the bandwidth, the Signalbox sees this as throws a wobbly as it does not have enough bandwidth to operate correctly.
The few questions this throws up are
1 - Does anyone know the minimum bandwidth that the box requires?
2 - How do I go about setting a QoS on my 7800n to set this minimum as always available to the Signalbox
3 - Has anyone else had a similar issue
I will be giving T-Mob a ring later on, but am not expecting the greatest of responses from them on something that is going technical (have you tried switching it off and on / have you tried it an another port / we will send you another box *please delete as required)
Cheers
Cheers
