- 26 Dec 2009
- North
My cousin is having some issues with his new build with high idle temps. Just sat in windows doing nothing it’s mid 60s.
I’ve been out of the game for a while but went over and had a look at build all seems fine. Repasted cpu with mx4, checked the mount and all looked fine. Even original paste had a nice spread so not a contact issue.
7800x3d
Nzxt kraken 360 aio
X670E MSI board tomahawk
Checked fans and pump plumbed into the correct header. In the software set everything to performance so pump at 100% because of curve and temp.
Weird thing is under load with R23 or Prime temps look fine at low 70s. In prime all core boosted to 4.4ghz
R23 boosted to around 4.8ghz (still lower than the 5ghz I should get) but again temps low 70s
7800x3d
Nzxt kraken 360 aio
