7800x3d Cooler selection - help
GA II is the best aio on the market currently and its right there.
Do you have any experience using both top air and aio? You sound like you dont. Cpu ihs is the limitation
You cant even read the graph...HIGHER IS BETTER ON IT
No it’s not the position one the main heat soak the to limit. That why the new be quiet is still a bad cooler and cost £80
That’s whys GA II can’t pass the artic 360 with the offset mount
