7900gtx or x1900 ?
12 Mar 2004
Scotland
Just been wondering.
Was the month wait for the 7900gtx 512mb card worth it over getting the ATi X1900 XTX???
They both seem to perform much the same.
Yup they are pretty similar. The 7900 leads in some games and the x1900 in others.
7900 runs cooler and uses less power but is a tad more expensive at the moment.
Have a look at some benchmarks and see how each card does in your fave games.
It seems at present ATI have better intelligence quotient (latin for image quality).
However, NVIDIA drivers are better & more stable. The GTX cards look much nicer with that metal cooler. They run cooler and more quietly, requiring less power.
Difficult choice between the two. If it weren't for the price, I'd say go NVIDIA
But no, that extra month wasn't worth the wait. We all hoped for a lot more from the 7900 series. We wanted 32 pipes, we only got 24. We wanted 700-750MHz, we only got 650MHz.
With any luck they will get it right again with the G80, we'll have to wait and see.
Agree, the 7900GTX isnt all that it was suppoesd to be performance wise.
Sure its about the same speed as the X1900 XT but it was rumoured to be quite quicker. Considering the better image quality & the prices you would have to say go for the X1900 XT.
wouldnt say better iq they seem 2 be very close since the7900's
speed wise they are close yes
gtx cards look nicer?? yes if you dont put them in your pc mines upsidedown so i cant see how nice it looks and yes i have a window
price no brainer £100 difference at the moe soon 2 change though
Difficult choice between the two/// only if you like 2 pay a lot more for the same perfomance
both great cards but the price at the moe ati wins
and you cant get the gtx's anyware
Yes, I suppose it would depend on the case you own. Anyway, looks better than a big white slab of plastic i.e. my saffire x1900xtx ;)
Not sure if the ATI drivers are worse or less stable? They seem pretty good at the moment.
No probs here running x1900 cat 6.2 on FEAR, Q4, BF2, Battlefront 2, Empire at war, X3, Bloodrayne 2, Fable, GT legends and Dungeon Siege 2.
i would say you can indeed be classed as a gamer
Performance atm is the same. The X1900 has better IQ but runs far hotter (and draws much more power).The 7900 is a much more power-efficient design - and a much smaller core.
Depending on how much pixel shader and SM3.0 stuff new games will use, the X1900 will pull ahead - its a more powerful chip in reality, but games dont use that power atm.
If i was planning to run 2 cards, id go for the 7900. The extra power draw, heat and the maturity of SLi (both in hardware and software) vs crossfire makes it a winner imo. Ofc, price is an issue too :)
Also, the stock cooler on the x1900 is criminally poor - were talking 90c (on XTXs) @ stock (and sometimes crashes) easily in well-vented cases. So if you do get one, do yourself (and your ears) a favour and get a VF900. The Accelero X2 wont improve temps (though it is quieter).
As far as im concerned - I heart my X1900XTX, but im cooling it with H20 :)
Oh, and I only ever run Omega drivers on my ATI cards :)
This post 4tw.
It really does come down to which games you are currently playing or planning to play.
Getting the VF900 for the x1900xt makes it the same price as the cooler quieter 7900 GTX.
This puts 30 odd quid to the price.
7900 GTX IMO
A sensible and balanced post.
Im mainy a nvidia man , but from what ive seen, reviews and benchmarks etc the x1900 looks by far the better choice + this week only = deal price
