Worth it is a hard thing to define. Is your CPU perfectly fine right now? Yeah. Would you see a benefit in some games that love the cache? Sure.
I mean, a 5090 is "worth it" for me, but would I buy one? No
You'll definitely see a bump in the numbers at that resolution, but whether it's noticeable is another matter.
I'd probably wait for the next generation.
sorry, should have mentioned that..
I game at 1440p 240Hz..
and the FPS are decent, but since my new GPU everything is smooth as butter, even when frames "tank"..
For an example, I ran the benchmark on Shadow Of The Tomb Raider, and got this... (sorry about the quality)
oh no 233. that's a powerpoint presentation lol
Save your money buy some speakers or something.
I'm not up to speed on AMD platforms but you could potentially get a boost from tuning your RAM if you haven't already and it's a capable kit.
You'll see a slight boost in performance, which will be game dependent. Really comes down to whether you view a £300+ net spend ( assuming you sell your 7900X ) as worth it or not. A more frugal/rational choice would be to wait for the next generation of AMD chips.
Definitely won't be drastic, bar one or two edge cases eg. MSFS 2020/24. Most games are GPU bound, not CPU bound at 1440p and 4K.yeah, its perfectly fine, I just thought there might be a drastic improvement for gaming, but will probably hold out if the gains are not going to be a game changer (pardon the pun).
So what is your speaker system then haha
Definitely won't be drastic, bar one or two edge cases eg. MFSF 2020/24. Most games are GPU bound, not CPU bound at 1440p and 4K.
