Permabanned
- 11 Aug 2012
- Scotland
Decided to give my 7900xt a bit of love after noticing hot spot temps were pretty high running at stock. Started running a bit of an under clock to keep in check. Re-pasted last night and made more of a difference than I expected. Found the old paste was quite hard and brittle. Used some thermal grizzly kryonaut & found I now get lower hot spot temp in particular and higher sustained boost clock as a result.
Dropped from 102c hot spot to 86c. Well worth the hour or so it took to do.
