7950 and water block
ocuk do not stock any 7950 waterblocks.
and I don't think they have any 7950's that are compatible with 7970 waterblocks.
There is 2 different versions of 79xx waterblocks. One version fits some 7950/7970's and the second fits other 7950/7970's . It's really confusing :(
Some 7950 cards are built using 7970 reference layouts, so are compatible with a 7970 watercooler. It will require lots of googling to figure out though.
True but they do stock EK 7970 blocks that also fit 7950's.
hello i currently have a 7950 with the following water block......http://www.overclockers.co.uk/showproduct.php?prodid=WC-237-EK&groupid=962&catid=1520&subcat=2327
can anyone tell me what cards OCUK stock that are compatible with a 7950/70 waterblock please
The block you have linked will also work with the following (plus more) 7950's:
MSI MSI R7950 Twin Frozr
MSI MSI R7950 Twin Frozr V2
Sapphire HD 7950 OC
VTX3D Radeon HD 7950 X-Edition V3
HIS HIS Radeon HD 7950 IceQ X²
Sapphire HD 7950 OC
Only certain 7950's can fit EK's 7970, they are no different than other companies blocks. It can be confusing as I'm doing the same now (looking for a 7950 + waterblock).
For example there is different variations of the MSI Twin Frozr. 1 of them uses 7970 pcb, the other uses 7950 pcb which is the one ocuk are currently selling. There is also many different versions of the sapphire 7950 oc. a lot of them are not compatible with any waterblocks.
