7950 help
27 Mar 2013
Nottingham
Just bought a refurb msi 7950 twin frozr III and a new PSU. Checked the PSU was working correctly with old setup, 7750, and everything was fine.
Now I plug in the 7950 the fans spin everything seems fun but monitor won't display anything. Any help?
Is it finishing the POST? Can you get into the BIOS? If you can get into the BIOS but not Windows then fx's drivers suggestion is a good shot. If you can't get into the BIOS then try reseating the card and power connectors. If it still doesn't work, and your old GPU does then that leans towards a 7950 that's broken and needs to go back. :(
