So is using Furmark safe to test max load tempertures its just i read a post saying that Furmark killing cards ?
Forget furmark. Run Heaven on a few cycles.
So uninstalled all drivers, and ran Driver Sweeper. Rebooted and installed the latest beta drivers.
Now the card is running a few degrees hotter! Wth!
40oC, Core: 880 Mhz Memory: 1250 Mhz all stock settings.
Is it faulty![]()
Does any one own a gigabyte 7950 or know how they perform?
If the difference in temperature is not big than i will just stay with MSI...
?Just fitted a new front fan to replace a cranky one on my HAF X. Dropped temperatures after one Heaven loop to a maximum of 57.
Makes a big difference, a good intake fan.
The one that came with the case was OK but stopped spinning properly. This one is too loud for 24/7 use but will undervolt it.
Well, Iv bought 2x BeQuiet Silent wings. I will mount them and see how they perform and if GPU temp will drop down...
I've got one of these being delivered today but won't get a chance to test it before the weekend. Have you tried a different driver version ?
