7950's on 7970 PCB
27 Oct 2009
West Sussex
Just for a reference for everyone really can we list all 7950 cards which have 7970 PCB and 6+8 pin design?
1. MSI Twin Frozr
2. Sapphire Vapor-X
3. Sapphire Dual X OC 950MHz edition (non boost)
Plenty of reports suggest that the Sapphire Vapor-X is volatge locked, meaning limited overclocks even if it does have the extended pcb.
Some guy reported buying an MSI 7950 which had the 7970 shaders. People were saying it's a fluke though and it must have been packaged as a 7950.
been able to up the voltage on mine. Have seen people saying theirs is locked though. Flashed mine to the 7970 bios with no issues which raised the stock voltage from 0975 to 1025 :D
I thought Vapor-X is only locked on Boost bios, but when you move to the stock clocks (other bios switch setting) then you can do it no problem.
The voltage "locked" issue is something unique to the HD750 Vapor-X thus you should be fine.
Thank you oweneades. I was a little worried due to sending back a Windforce 3X 670 as the 7970 excels when overclocked. So if I had no or little ability to do so, I'd be in a pickle. Also I ordered at 3:50PM yesterday but seems as if I missed the cut off time, it's still in the warehouse :mad:. I can last another day on CS:GO :D.
I've read people had success to unlock voltage for Vapor-X by flashing 7970 bios.
My stuff didn't leave warehouse yesterday either and I've placed the order just before 1pm.
Are the memory timings in the ram equal between the 7950/7970?. I flashed my 6950 for the extra shader unlock but didn't flash the 6970 BIOS due to different memory modules between the 6950 and 6970 cards. The method I used kept the 6950 memory timings.
Thank you for the info and also for sharing your warehouse problem as I've been kicking myself all morning for not ordering earlier than I did. I'd still be waiting till tomorrow regardless it seems. I hope you and I get our confirmation of shipping mail today at some point :).
If the card is on the same PCB I'd imagine that if anything the timings would be looser hence potentially allow extra OC.
Don't quote me on that just yet ;) I'll try to dig out the source.
As long as I get my block by the weekend then I'm a happy ;)
I have the Sapphire VX - Leave the bios button alone (850/1250) and it will clock and MSI afterburner will adjust the VDDC - If you press the bios button to 950/1250 it will lock the voltage and clock very poorly... Mine is currently 1170/1500 with 1140mV but its a bit toasty at 69Deg on a long run.
Bugger, may have to look at a diff card.
I'd say just go for any 7950 which is on a 7970 PCB and then get a 7970 block for it. There isn't any difference in terms of overclockability (silicone lottery aside) between the 7950s which are on reference 7970 PCBs, only difference is the cooler (which doesn't matter) Just go for one with a good warranty and price :)
+1
How do you tell if its a 7970 on a 7950 though? I really want to get the Asus 7950 v2 but not fully sure if its ref and 7950/7970 PCB. I want a black PCB too, picky I know but that's what I want.
