- 2 Sep 2013
Ah, I am aware of what you are talking aboutYour old 8 core was struggling because it was old and slow, not because it only had 8 cores. A 7700x in gaming is just as fast, if not sometimes faster than a 7900x & 7950x. More cores does not equal more gaming performance (at least on Ryzen). Also more clock speed alone does not equal more performance. It's just a shame, as you probably could have saved yourself £100-£200 and put it toward something else in your rig, or upgraded to the 7***X3D later on, if you felt the need.
If you're happy with it, that's great. I'm not taking the ****. Just want to point out that cores and clocks are not everything, especially for gaming. It's a whole different kettle of fish when it comes to productivity. Something to bear in mind for future purchasing decisions.
Back to OP, I'm using a Noctua U12A with the fan curve set at a very modest setting to keep noise low. The CPU being put into (currently) a 65W Eco mode never breaks 50C. I'd expect it to be around 70C when 105W Eco Mode is finally able to be activated through the BIOS. And at 170W, well, it's 95C of course.
In most cases, the cooler I don't think is that much of a big deal, certainly not for air coolers anyway. As I've noticed that whether it's 65W setting or 170W setting, the U12A at full speed or reduced speed, sits roughly in the same bracket of speed 4.5Ghz for 65W, or 5.0Ghz to 5.1Ghz sustained for 170W, but the temps are instantly at the previously mentioned numbers, but no amount of airflow appears to be impacting on them at all (even the 65W mode). So for air coolers, I think virtually any air cooler will be fine so long as they mount well onto the CPU. With possibly only one or two able to make a difference. Otherwise, I think water may be the better route.
