7970 crashing help
21 Jan 2012
Hereford, UK
hey guys i have a 7970 gigabyte oc
so my problem is that recently doesn't matter what game i play my game freezes and i get message "display driver has stopped working and recovered"
any ideas as to why or is my card dying?
i have uninstalled drivers got new ones used old ones but nothing works grrr
any help greatly appreciated thanks :D
don't have this option unfortunately
my power supply is a possible factor its 750w which is enough but only bronze and i have had it years im wondering if its on way out
my cpu is clocked to 4.9ghz but even @ stock it does it so defo gpu related and i get driver error message
I am assuming it is the same with any benchmark programs? Can you temporarily install windows on a diff. drive to see if the same happens, so we can rule out software completely?
tried with stock cpu clocks? just to rule out your oc that's causing gpu drivers to fail
EDIT: just read you already did that
would be good if you could test with another psu
yeah tried standard clocks still same
just done fresh install of windows today doesn't do it as much but does do it still (so software was playing a part it seems)???
so now its intermittent
may see if i can take it to a friends to test it but he is a trek for me
im thinking psu
just ran heaven on extreme and no crashes with my card overclocked as well this is odd but on steam i get crashes also 3d mark ran fine
it is a brain teaser for sure
