Do NOT touch Furmark/Kombuster, its a completely unrealistic load for your GPU to handle, if anything, the heat and power it can draw has the potential to damage your GPU.
If you want a 'realistic' heavy load test, use Unigine with some hefty settings...Or if you have the full version of 3dmark11, loop the 4 GPU tests at your native resolution.
Memory volts, it will max out at 1.7v, you will never ever ever need 1.7v, you will hit memory correction before you can even consider needing that much voltage. If you're pushing the memory, 1.65v is about your limit, many hit 1800+ on the stock 1.6v, I needed 1.63v for 1950mhz.
