7970 Trifire Problem
11 Feb 2008
Before I RMA this card back I just need a bit of a sanity check please...
I bought a Gigabyte Z77 G1 Sniper 3 motherboard and 3 x Powercolor 7970 LCS graphics cards from OCUK.
Once built I found the motherboard to be faulty. As it would only ever display any signal to the monitor from the on board graphics card. At that point I was not sure if it was the graphics cards or the motherboard. So I RMAed every thing back to OCUK.
Ended up being charged for the RMA on the graphics cards as they said they where not faulty. Not a big fan on OCUKs RMA system but thats another story.
They found the motherboard to be faulty sent out a new one and returned the graphics cards. I took yesterday off work to build the PC.
All went OK I installed a new version of Window 7 64bit on a new SSD drive. All seemed fine so I let Windows 7 do all its updates so it was the current latest version. After that I installed all the latest motherboard drivers.
Then I figured time to install the ATI Drivers and set up Tri-Fire.
Anyway I could see all 3 7970s recognized in Device Manager. It had all 3 down as Generic Graphics something like that it was normal.
After installing the latest ATI Catalyst Drivers which went fine no problem. I rebooted for the first after installing them. Only to find the PC just hangs at the Windows 7 Starting Logo. I use a G19 Keyboard that goes on and off when Windows 7 starts. It did that but the Window 7 Logo still stayed on the screen it had just frozen.
After a lot of trial and error. I found if I unplug the power to one of the 7970s it would boot into Windows 7 and run perfect with the 2 cards in Crossfire.
My first thought was maybe a bad power cable. So I used the connections off of one of the working cards plugged them into the bad card. Same thing stuck at Windows 7 Logo.
To eliminate the PSU not being able to run 3 cards. Although it ran a 6990 & 6970 no problem. Its a Dark Power 1200 Watt. So it should run 3 x 7970s no problem.
I just plugged in one good graphics card and the bad card. Again it booted only until Windows 7 Starting Logo. If the bad card is plugged in it just will not boot all the way.
Yet any combination of the other 2 is fine. It seems to me that 7970 has some sort of fault.
But before I go through the hassle of RMAing it again. Does anyone have any ideas ? I am not supposed to do anything other than plug them in with Crossfire Bridges on 7970s ?
Just to clarify its only 1 card out of the 3 that seems to be bad. The other 2 are working fine I have them in Crossfire fully working. Ran Heaven Benchmark and played SWOTOR for a good while it ran perfectly.
Run with just the bad card in the mobo. Try it in all the slots if the pc won't boot then RMA the card. Also try the good cards one at a time in all the slots to make sure you have not missed anything.
Hmm running just the bad card would be a right nightmare to do. As the rig is water cooled its all cut to length on the tubes and the cards use those little metal bridges between them. So taking out 2 cards would mean draining the entire system then cutting new tubing its a long process lol. I love water cooled would never go back to air but if anything goes wrong its pita.
I am pretty sure the mobo is fine. It has 4 PCIE Slots I use 1 to 3 with the 7970s and the 4th has my second SSD which is an OCZ Ibis uses the last PCIE slot. Which works no problem also to test I did unplug that and had the same Windows Logo issue.
Think I will RMA just hope OCUK are thorough enough I will explain in the RMA.
On a more positive note anyone that has a Trifire 6970 or a 6990 & 6970. Runniing 2 x 7970s are a fraction faster than the 3 cards. Not by much but it is a little faster in Heaven at least.
