I bought a areocool dead silent 40mm fan (1500rpm USA version) and decided to use the 7volt reducer cable that was included, as the motor of the fan and was quite loud and annoying.. After about 2mins of using the volt reducer cable, the cable was very warm to hold at 1 end.
So I thought I try another fan reducer cable as I have 3 of these "dead silent" fans in my case, with the other 2 running at lower speeds because they are the uk versions.. So I swapped the reducer for another one and the same thing happened again, but the cable may not be quite so warm.
Anyway I have left it connected, its been running for about 3hrs now and no smoke or flames so far.. So guys is it normal for volt reducer cables to get quite warm?
