The really exceptional chips I find out of the system OEM stock will be kept for 8 Pack system builds. The next best will be put in the high end overclocked builds and so on. Retail chips will not be binned at all so thats a silicon lottery. I dont want average chips in my systems, hence the binning process.
Bundles will be available yes later but I doubt just chips will be for some time as there is too much room for end user error.
So what kind of clocks are we to expect in 8pack builds? When you say the best chips, what criteria are you talking? Lowest volts/temps at 4.4GHz? Or highest stable overclock?
Are you saying here that the chips supplied in OCUK stock speed 3770K systems have been tested and found inferior to the ones supplied in the 4GHz systems which in turn were found inferior to the ones in the 4.5GHz systems? (Asking for clarification as it certainly sounds like that).
I think he just means the overclocked ones are binned, and the stock ones aren't tested asides from usual function. I don't think they keep the rejects for stock builds, but I could be wrong. I doubt anyone running stock cares about what volts/temps they can run at overclocked speeds. Presumably they use the OEM chips in their builds so it's possible they'd be tested as not ideal for 4.4GHz
