And I take it AX1200i will just be same as AX1200?
Dont suppose you know anything about the corsair Link? never seem to fina many retailers that sell it and think its what I need to use the extra features on my PSU
Hello. No they are not. Also we are not sure when they will release the sleeved cables for the 1200i
I emailed corsair about this about a week or two ago asking if they were compatible with the AX1200i and got this :
Regarding corsair link, the PSU comes with the equipment needed. You plug this device into the port on the PSU and the other end onto a usb header. I have not connected mine up but I dont think you need anything more than that.
sending back for refund as I asked before hand and was advised it was fine.BTW... finished look on your build is amazing!! didnt realise could fit so many rads in a 800D!! I will be going for a top 360 and 140 rear. Dont think my single gpu & cpu loop would need it, how difficult was the extra 240mm rad in the bottom to fit? Think with that loop I could do my SLI 680 (when i can afford it) and chipset.
how ever much a pain it was to me it looks well worth it!!
do you have any idea about the fan issue i have? really cba taking them off but they are wrong. cant see it being a major problem but just want to be sure its not going to mess up air flow
