802.11g wirless Help PLEASE! ??
Permabanned
12 Feb 2011
Swansea!!
Right i have my mates laptop here done a fresh install.
oldish laptop.
bottom of the laptop its got a card for wirless.
in the device manager its showing an error like a ! sign in yellow.
one is Network Controller with a yellow !...
second is PCI SIMPLE communications controller with a yellow !..
this Obviously means that the drivers aint installed.
i have got a ligit driver finding program BUT does not pick up these.
if only i didnt loose my CD!!!!!!!
IT DONT REALLY SAY THE MAKE EITHER!!
ill savage most details off now..
802.11g
like a barcode then..
22b001300
V4ALE3E007093XXXXX
Another code on there . p05-83001300
it has a black chip on there. on top of that has
Ra
RT2560F
QA46280D0
0428ST...
Revsese side then.
S/N- MP54G2B0409013735
Another 2 codes then
one with barcode --> 4910596264
another with barcode --> 0011090b5d3b..
this is all the information i have ANY HELP would be apprechiated! (:
thanks for looking!!:confused::confused::confused::confused:
You could try connecting it to your router with an ethernet cable and running Windows update to see if it finds the drivers for you?
if i were you id save myself a lot of hastle and maybe get driverpack solutions 10.6 from cough cough thepiratebay cough cough use that to get your wifi driver and then delete driverpack as if it never happened. i just spent 15 mins looking online for you and its pretty hard to find and nothing but driver update software came up.
i dont use those sort of sites ;) cough cough ;)
awesome, yeah thats the one (2.4gb), not that i know what your talking about, can't believe some one would have recommended you to do it that way
