Thats awesome how do yo fill 1.5TB of space
I use the four 300GB drives in a Raid 5 array to store video, movies and tv shows, don't want to lose them! The two raptors are in raid 0 for speed.
Pandobear said:Has anyone got details of the vdroop mod for the P5LD2 Deluxe>? I can find the ones for the WD, but not the LD.
Blue078 on XS said:The P5LD2 uses the same voltage regulation chip as the P5WD2 (ADP3181)
Solder a 50K multiturn VR to pins 17 - 18.
The best setting I found was 42k, set this before you soldered it in.
This gave .075 - .085 voltage increase on what is set in the bios. But you`ll get next to zero droop under load.
So set to 1.325v in bios ( stock on my processor ) you`ll get 1.400 - 1.410 measured with a DMM . Probe reads fractionally higher.
If you have the time a Heatsink on the MOS FETs at the side of the socket wont go a miss.They get quite hot. Also if you`re water cooling you`ll need a small fan blowing accross both the heatsinks otherwise they get Bl**dy hot indeed.
Hope this helps
Arthalen said:No, wont overheat, you'l just suffer the woes of throttling LOL
Arthalen said:EDIT NOTE: Do not disable Throttling. Throttling is your thermal friend, your performance adversary. It tells you need better thermal management or to drop the voltage off a little and will keep your chip happier in the long run.
Arthalen said:Well its under way, looks like I can add another 100Mhz to my overclock as temps seem stable at around 67C.
Voltage stability is rock solid at 1.340 - 1.345. Much goodness.
*Keeping fingers crossed Prime passes a good few hours of testing *
sablabra said:67c on bigwater? Wow, it's worse than I could imagine
Pandobear said:I have just done the pencil volt mod, could not have been easier. The oddest thing is that now it actually runs 3.8 GHz at stock voltages, which are obviously 0.1v higher than set, but this is a full 0.15 under where I had to have it before. Runs cooler now also, obviously because of the lower vcore. What I don't understand is what is the downside of this mod? There must be one otherwise surely Asus would do it as standard? Anyways, thanks guys vcore does not move more than 0.02 now, and only upwards! woohoo
Last update before I hit bed - running fine at 3.8Ghz on Full Dual Prime load - temps same as what they were at 3.7, no voltage change necessary (yet lol), voltage is super stable for me
