- 27 May 2006
- Teesside UK
Hi,
After updating my second HD from my master HD with true image, (ie, I cloned my master drive onto my slave drive as a backup incase my master drive crashes, as this saves me time and I dont need to reinstall everything again.)
But for some reason now my master drive will not boot up sometimes and it either says that there are missing files or it just freezers on loadup screen
I dont think it is anything to do with the cloning as my slave drive is now been used as my master which is also a maxtor 80gig and it is working fine
I have tried re-formatting my problem drive and cloning the good drive on it again, but I still get this random fault
Would you say that it is the drive its self that is causing the fault? or is it a software fault?
any help would be great.
