8150 vs 8350
22 Jan 2005
OcUK,
For my Numerical Modelling PC (No GFX needed), I require a true 8 core processor. Naturally I am drawn to the 8350 for the increase in clock speed, but does the price reflect this? Does the 8350 bring anything else to the table?
Steve.
There's no such thing as a true 8 core processor outside of the server market (Xeon's) and they are extortionately expensive. AMD processors do not have 8 independent cores which is what would constitute a 'true' 8 core design.
Ignoring number of cores a 3930K would give the best performance in practically every piece of software available, it'll probably outperform the 8 core Xeon's in most things and is less than half the price.
There a pretty complex chip, i did read an AMD PDF explaining the inner workings on the chip, not that i can find it right now....
It seems they have 8 Integer cores and 8 threads @ 128Bit or 4 threads @ 256Bit, depending on what is asked from it.
They have 4 Modules with 2 cores in each module, When the Threading is high enough either by application or multiple threads running on the OS from multiple apps you will get 8 threads @ 128Bit, if threading is low the 2 cores in each module with join up to form one big core and thread as one through a 256Bit pipe.
Does that mean an i7 would perform the same as the 8350 for parallel jobs that use 8 cores? Are there benchmarks for this level of parallelisation?
how does the piledriver not have true 8 cores?
So may I ask again... What would perform better for an 8 thread numerical process - the 8350 or an i7?
Its hard to say for sure, in encoding for example (Depending on the application) the FX-8350 performs better in some, in others the i7 performs better.
They are probably roughly about the same, but the FX-8350 will use about 40/50w more power to do the same job.
Hmmm. I wish it was more clear cut.
"7-zip is almost the perfect scenario for AMD's Vishera: a heavily threaded integer benchmark. Here the FX-8350 is able to outperform the Core i7 3770K."
The 3770k is almost £100 more expensive, but going for the AMD would require a Motherboard change.
An FX8350 has 8 integer cores,with a pair of cores sharing a FPU unit. The FPU can actually run two FP operations at once(a sort of SMT like arrangement),although each operation will run slower, but throughput would be higher.
