8320 Overclocking and temps
4 Mar 2008
I've just setup up an FX8320 on a Gigabyte 990FXA-UD3 and its being cooled by an NH-D14.
I've set the multiplier to 22.5 which takes it to 4.5GHz with 1.45v. So far so good.
What I'm struggling to understand (this is my first AMD CPU overclock for a while) is that the temps are very low. The current temp under a prime load is 36 degrees which seems to low. Idle temp is 15 degrees. I've tested using Core Temp and HWMonitor.
The second is that using Core Temp, I can see all 8 cores fluctuating from 4.5 to 2.9 to 4.5 and so on. This to me looks like throttling under load.
What do you think? Also any tips to improve the overlock / settings would be appreciated.
Yes, the settings are as below ..
CPU Clock Ratio - 22.50
CPU Frequency - 4.5GHz
Core Performance Boost - Disabled
CPB Ration - 20
CPU Unlock - Disabled
Cool & Quiet - Disabled
C1E - Disabled
SMV - Disabled
CPU Core Control - Automatic
Core C6 State - Disabled
HPC Mode - Disabled
APM - Enabled
Cant get my head around the low load temps. On my 4770k @ 4.5GHz, that would be in the 50-60's under water.
Which are you looking at though as there is CPU temp and then there is 'package' temp?
My H100 keeps it below 52 with cpu max at 50.
