£850 first pc build
28 Dec 2012
Hey, looking for some advice on my first pc build I only really use my pc for gaming and a little programing, Here's what I'm thinking
Case: NZXT Phantom 410
PSU: Corsair GS 600
Motherboard: ASRock Extreme 6
CPU: Intel Core i5 3750K
Cooling: Corsair H70 CORE
RAM: Corsair Vengeance 1600 16GB
GPU: MSI 2GB 7870
Hard Drive: 1TB Seagate Barricuda
Shall i bother with a SSD I hear there are loads of issues with them still?
What should I expect from that rig will it be capable of ultra setting on most games?
That's for the help in advanced :)
I think hono must cheat, because everytime I see him post a build it is pretty much spot on for the budget at hand. Stop cheating hono....at life...
I live life by my own rules.......no need to cheat ;)
There is always room for a difference of opinion. I enjoy seeing how other people balance the builds out. I'm over slightly, more so if an optical drive is needed. The 7950 is definately better and seeing as he cops some free games it helps sweeten the deal :D
EDIT
Just to prove my point, you can go mini-itx if you want to be different
YOUR BASKET
1 x Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games £239.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x Gigabyte Z77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard £98.99
1 x Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) £89.99
1 x BitFenix Prodigy 'Yin' Mini-ITX Cube Case - White/Black £64.99
1 x PC Power & Cooling Silencer Mk III Series 500W '80 Plus Bronze' Modular Power Supply - White £59.99
1 x Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) £51.98
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £35.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £13.99
Total : £848.50 (includes shipping : £10.50).
Bang on the money, mobo has wifi as well, added the optical drive incase it was needed after all. I look forward to seeing what the OP settles for :)
Yeah, there's not much between them. I would go for the first build just for the option of a monster cooler. I like the look of the small cases, but don't think I'd ever get one
He could add a CLC cooler down the line, like I've suggested to you because you have tall RAM. Even a cheap one would do. If it proves to be a little noisey he can ditch the cheap CLCs stock fan, sandwich the radiator between the cases two supplied fans and add say a 200/230mm fan at the front of the prodigy :)
I read some reviews on the gigabyte mobo you said abduction aprently it's not great is that true? Ddefiantly want watercooled so not worried about how much extra that costs . Other than that like the first spec a lot defiantly contemplating it :) thank you and recommendations on a watercoler or is the original one I specified good enough only problem with the card is to big for nzxt phantom 410 and I completely feel in lo've with that case? Thanks :)
I've used the Z77-D3H plenty of times, it's a good mobo. 3 year uk based warranty and has a dual BIOS too. It's not voltage locked like most entry level Z77 mobos and overclocks well. It's not for SLI/Xfire but this means spending more on the mobo to get that feature and you would need to up the PSU spec too depending on the GPU you use.
The shinobi can't mount the H100i CLC but you can use the smaller radiator versions like the H80i. If you like the NZXT case that's cool but it is more cash. I'd rather pump cash into the GPU budget than the case if working to a strict £850 budget. How you balance the build is really down to you, I look forward to seeing your next spec :)
Yes SSDs are awesome. 10 maybe 20 seconds tops to boot into windows ;)
Your basket
Product Name Qty Price Line Total
HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card (H795QC3G2M) with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card (H795QC3G2M) with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games £239.99
(£199.99) £239.99
(£199.99)
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £179.99
(£149.99) £179.99
(£149.99)
Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £105.98
(£88.32) £105.98
(£88.32)
Corsair 2013 Edition Gamer Series GS 700W '80 Plus Bronze' Power Supply (CP-9020064-UK) Corsair 2013 Edition Gamer Series GS 700W '80 Plus Bronze' Power Supply (CP-9020064-UK) £79.99
(£66.66) £79.99
(£66.66)
NZXT Phantom 410 Enthusiast Midi Tower Case - Black NZXT Phantom 410 Enthusiast Midi Tower Case - Black £79.99
(£66.66) £79.99
(£66.66)
OCZ Agility 3 60GB 2.5" SATA 6Gb/s Solid State Hard Drive (AGT3-25SAT3-60G) OCZ Agility 3 60GB 2.5" SATA 6Gb/s Solid State Hard Drive (AGT3-25SAT3-60G) £62.99
(£52.49) £62.99
(£52.49)
Corsair Hydro H60 V2 High Performance Liquid CPU Cooler (Socket LGA2011 / 1366 / 1155 / 1156 / 775 / AM2 / AM3) Corsair Hydro H60 V2 High Performance Liquid CPU Cooler (Socket LGA2011 / 1366 / 1155 / 1156 / 775 / AM2 / AM3) £59.99
(£49.99) £59.99
(£49.99)
Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) £51.98
(£43.32) £51.98
(£43.32)
Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI38G160C9K) Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI38G160C9K) £39.95
(£33.29) £39.95
(£33.29)
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £13.99
(£11.66) £13.99
(£11.66)
Sub Total : £762.37
Total : £929.84
What you think?
Plans have changed!
Basically I've got about a 1000 to spend Now as I gave up smoking can now afford more :) I have already purchased the case which is a storm Stryker seen it loved it had to buy it lol any good specs? Also should I go for a fully modular psu or standard am unsure on what's best for that budget please help!!!
