8500 Ballistix problem.
26 Sep 2007
Hello!
I am having trouble getting my Ballistix 8500 to reach 1066mhz.
I have 4gb installed. It is stable at 800mhz at 5-5-5-15 2T timings. The voltage is at 2.2v. And the motherboard I am using is a Asus Striker Extreme. The CPU is overclocked to 3.6ghz with a 1.45v its a Q6850. Everything seems stable and I score 16k+ on 3d marks but would really like to be running my ram at the rated speeds.
If I try 1066mhz I get BSOD before windows loads and sometimes it will not boot up.
Any help is grealty appreciated.
Not exactly sure what you mean by up the chipset voltage. Up the NB?
And any idea what the standard voltage for my motherboard is?
Thanks.
