8500 GT Cooler replacement
24 Aug 2004
Hi all,
I have an 8500 GT in my HTPC with the stock cooler still attached. It was never the quietest thing but now the bearing is going on the fan (within a few months of purchase!) I want to replace the cooler with something else.
I bought an Accelero S2 and it fitted the card great, unfortunately the top wouldn't go back on the case afterwards as the heatsink is so high! :o
Anyone got any ideas as to another quiet / silent cooling solution for the 8500GT?
Dave
Something along the lines of a Zalman VF700 or Zerotherm 700 series would do nicely. You will have to check for compatiability though. VF900 would be way overkill for a 8500.
