8700K questions and advices
Just put 47 on all core at 1.2, below i had BSOD.
Deactivated Bclk aware adaptive voltage:
SVID should i leave it or not?
Had to put 1.225 and go for CPU VCCIO voltage and CPU System Agent voltage at 1.16, got some game freezing during loads (no idea if related but seems good now)
60c in game max (assassin's creed origins. Far cry 5)
Are those settings fine?
if you have suggestions.. :)
Tried 4.8 at 1.25
Svid Auto.
No other changes
The temperatures did not seem to change from previous settings. Isn'it weird? It still maxes out at 60/61
Hi,
I need some enlightments about OC stability test..
Just tried an occt. I realized it was maxing at 4.6 because of avx offset.
I changed it to 0 but then, error on core 1 and test stopped.
Should i test with the avx or will it give me a "fake" result.
I mean, i know 99% of program does not use avx but if occt use it and i have it at 4.6 instead of 4.8 that does not give me a real idea of the stability of my oc..
What should i do?
