8800 fan speed
6 Mar 2007
Is it okay to set the fan speed on the 8800GTS to 100%? I don't mind the sound, just wondering if it might break the fan or bearings or something?
It drops it by 12C on mine from default.
It won't really affect the lifespan. But why would you want the fan to run at 100% all the time? If it can't run stable without running at 100% then there's a fault.
As for reducing temp - absolutely unnecesary.
Out of interest, which drivers are you using and which tool to set fan speed?
