8800 gtx maximum shader clock speed
10 Sep 2006
ive just added an ek8800 block to my loop and have started to overclock the card useing a modded bios my question is what a safe clock speed for the shader? right now im at 705mhz/2140mhz/shader@1400
just push it til it starts to artifact or you encounter stability/temp problems, then pull back around 10-15 mhz.
That should give you your stable max OC at that voltage...
well what im really after is someone that has found the max limit for their shader clock speed to give me an idea what to shoot for without having to flash the bios 10 times.
