8800GTS mem problem
19 Sep 2007
Need your help with my 8800GTS...!
I am running Vista Premium and my 320MB 8800GTS is only showing up as 256MB in my Windows Information...
How come? And how can I fix this?
I'm sure your card does have 320Mb. Check with everest/cpu-z etc.
If it's just a windows vista glitch, why are you bothered about what it says?
errr. the 8800 cards only come with 320mb, 640mb (GTS) and 768mb (GTX).
They don't make a 256Mb 8800 GTS.:confused:
And the fact that the manufacturer number of the card is VD-BFGE86256GTSOCE
"86256" being the key = "8600 GST 256Mb" Check nvidia's website and don't trust shopping search engines.
Also if it was a 256Mb 8800 GTS the core speed is 710Mhz which is 26Mhz more than the fastest Ultra GTX card costimg more than £500.
So if you do really have 710Mhz 8800 GTS 256Mb then I would count myself very, very lucky ;)
Well, I have seen the exact same card in PC World yesterday, with 256MB written on it.. Very strange...I will have to tell them.. :) :) :)
Yes but does is say "8800" or "8600" - sixes can look like eights if you don't look closely ;)
ANd you best tell Nvidia that they are making them cause they don't know about it :p
